The following topics were updated to reflect that the only JDK version that CA Process Automation Release 4.2 supports is JDK 1.7. This requirement applies to Orchestrators only.
Install the Domain Orchestrator—This existing topic was updated with new pages that were added to the Installation wizard for this release.
Install an Agent Interactively—This existing topic was updated to document a new check box that specifies whether the agent is to use simplified communication on standard Internet ports or deprecated communication on port 7003.
Post-installation Support for CA EEM Upgrades—This new topic describes how to upgrade an existing CA Process Automation Release 4.2 when you either upgrade the CA EEM release version or generate new certificates with longer key lengths.
F5 Load Balancer Prerequisites—This existing section was modified to add changes to support simplified communication and to remove references to the Primary Node. Other changes were made to improve usability.
NGINX Load Balancer—This new section documents how to configure the NGINX load balancer, which supports simplified communication. This load balancer is a good alternative to Apache, which supports only deprecated communication.
