The following documentation updates have been made since the last release of this documentation:
Example: How Touchpoints Enable Content Portability—This new topic describes how creating the same touchpoint name mapped to different agent hosts in different domains lets you seamlessly move a process across domains (or across environments) without change.
Example: One Individual in Two Referenced Active Directories—This new topic provides an example of CA Process Automation users being referenced by CA EEM from multiple Microsoft Active Directories, where the same user is defined to more than one referenced AD.
Configure CA EEM Security Settings for the Domain—This existing topic was updated to include the Default Active Directory Domain value, a field that is valid only if CA EEM is configured to use multiple Microsoft Active Directory Domains.
Configure Domain Properties —This existing topic was updated to include new fields that are related to host group configuration and to purging reporting data. Other topics similarly updated for host group configuration:
Install an Agent Interactively—This existing topic was updated to document a new checkbox for specifying whether the agent is to use simplified communication (with NGINX or F5) or deprecated communication (with Apache or F5). It is also noted that Windows supports jre7 as well as jre6. Other topics updated to address new communications:
Scenario: Set up Touchpoints for Design and Production—This new scenario combines existing information to show how configuration options used in a production environment differ from those used in a design environment.
When to Avoid Using Host Group References as Targets—This new topic addresses an impact of specifying an IP address as an operator target for a process to be distributed to an environment or domain where the target would be a different host. Processes exported and imported as a content package cannot be modified.
Configuring Operator Categories—All topics in this existing section were refactored to remove field descriptions that were added to the User Interface Reference.
Plan the Folder Structure—This existing topic was rewritten to accommodate the requirements of exporting a folder as a content package. This new export method requires that all objects for a release version reside in the same folder.
Purge Objects and Folders—This existing topic was updated to include what happens when you attempt to purge checked out objects. This action is newly supported in CA Process Automation r4.2.
