Previous Topic: Preparing Windows ServersNext Topic: Web Browser Support
Verify That the Windows Servers Are Prepared
Before you begin the upgrade, verify that the following conditions are met. Failure to comply with these requirements can result in data loss, increased down time, software conflicts, or a failed upgrade.
Verify that the following conditions are met:
Stand-Alone Server
Distributed NFA Console Server
Distributed Harvester Server
Distributed 3-Tier DSA Server
  • (Recommended) Remote Desktop connection is enabled to allow remote access
  • Static IP address is assigned to each server. Set the Harvester server IP address to match the flow export destination that is assigned to each router.
  • The following third-party software is disabled until the upgrade is complete: Antivirus, server monitoring, and maintenance software. If you enable antivirus scans later, exclude the CA Network Flow Analysis installation path and its subdirectories.
* The upgrade program does not open or does not complete successfully unless this requirement is met.
** If the server fails to pass this check, a warning message opens.
General Notes:
Localization Notes:
