CA Network Flow Analysis 9.2.0 supports upgrades of software versions installed on servers with the operating systems noted in the following table:
Pre-Upgrade Software Version |
Operating System |
NFA 9.1.2 or 9.1.3 |
Windows Server 2008 R2 Standard edition (all components) Red Hat Enterprise Linux 5.5 or 5.6 (Harvester) |
We support Windows Server 2008 R2 Standard edition for all components. For help upgrading your Windows operating system in preparation for the upgrade, contact CA Technical Support.
If you add components on new servers to your upgraded configuration, you can install the software on servers with the following operating systems:
The servers must meet the following requirements:
Appropriate language packs installed on all servers for localized deployments
Notes:
If you have either of the following special situations, ask for help from your CA Support Availability Manager:
