Install the following software on all of the Windows servers, logged on as a user who is a member of the Administrators group:
If the installation server does not have JRE version 1.6 installed, the installation or upgrade program fails to launch. We recommend that you install JRE 1.6u41, the version that was used in CA Network Flow Analysis 9.2.0 testing. Untested JRE versions may produce unexpected results.
If the .NET Framework software is missing or version 4.0 is installed, a prerequisite check causes the installation or upgrade program to exit.
Required/Optional |
Servers to Configure |
Required |
All servers |
