Make sure the NFA console or stand-alone server is registered as a data source with one of the following:
Note: CA Performance Center should be installed on a Linux server that does not have a Harvester component installed.
If you have CA Performance Center 2.2.x currently installed, upgrade to CA Performance Center version 2.3.x now. For instructions, see the CA Performance Center Installation Guide.
If CA Network Flow Analysis is not registered as a data source, some of the function links on the Administration page are disabled. For instructions about registering with CA Performance Center, see the CA Network Flow Analysis Administrator Guide topic "Register CA Network Flow Analysis with CA Performance Center." After you register, review the results in the CA Performance Center Console and NFA console. Make any adjustments that are needed.
