Preparing Windows Servers › Configure Data Execution Prevention (DEP)
Data Execution Prevention (DEP) helps to prevent code executing from data pages. This topic describes how to configure the appropriate DEP policy level.
Required/Optional
Servers to Configure
Required
All servers
- Log in as a user who is a member of the Administrators group.
- Open the Control Panel and click the System link.
- Click the Advanced tab in the System Properties dialog that opens.
- Click Settings.
- Click the Data Execution Prevention tab in the Performance Options dialog that opens.
- Select "Turn on DEP for essential Windows programs and services only."
- Save your settings and exit:
- Click OK in the Performance Options dialog.
- Click OK in the System Properties dialog.
A message opens and informs you that you must restart your system to implement the new settings.
- (Optional) Restart your system before you install or upgrade the software.
If you proceed without restarting the system, the prerequisite test displays a warning about the DEP configuration.
