CA Network Flow Analysis 9.2.0 supports upgrades from the following versions to the current configuration:
From |
Upgrade To |
NFA 9.1.2 operating with |
NFA 9.2.0 operating with |
NFA 9.1.3 operating with |
The following architectures are supported for upgrade:
CA Network Flow Analysis 9.1.2 is the earliest software version that you can upgrade directly. If you have an earlier version, upgrade to version 9.1.3 before you proceed, as described in the CA Network Flow Analysis 9.1.3 Upgrade Guide.
Notes:
Note: CA Performance Center and CA Network Flow Analysis cannot be installed on the same server.
