Previous Topic: Browse Repositories DialogNext Topic: Modify Local Address Book Properties
Users Dialog
The Users dialog lets you select a user defined to a specified repository that you want to use for the global address book.
This dialog contains the following fields:
User Name
Specifies the name or user ID of the user that you want to use for the global address book.
Full Name
Displays the full name of the user that you want to use for the global address book.
