Previous Topic: Modify Global Address Book PropertiesNext Topic: Users Dialog
Browse Repositories Dialog
The Browse Repositories dialog lets you choose a repository or domain from which you can select users or user groups for an address book. For hierarchical directories like Lightweight Directory Access Protocol (LDAP), browse in the displayed tree to locate the container in which the user you want to select is a member.
This dialog contains the following field:
(Repositories)
Displays a list of the available repositories and containers defined to the entire domain.
