Previous Topic: Connection WizardNext Topic: Multiple Address Books
Address Books
Address books contain a collection of information regarding remote hosts you connect to. The purpose of the address book is to provide a central and easy way to access computers and hosts you use. An entry in a book describes the address of the remote computer and the protocol to use to connect with along with user credentials. Passwords can be optionally stored and configured for manual entry for security precautions. Address books may be nested to any degree for ease of use. For example, entries can be organized by department, region, country, or any other way that defines your enterprise. Two types of address books are available:
Global Address Book
The remote control manager defines this address book.
Local Address Book
This address book is defined and customized by the local user of the viewer computer. It appears in both centrally managed and stand-alone environments. You can populate the local address book by dragging and dropping address books and computers from the Global Address Book pane into the Local Address Book pane or by simply creating your own entries manually. Additionally, you can import and export local address books.
Note: You cannot drag address books or individual computers from the Local Address Book pane into the Global Address Book pane.
Note: A computer can be a member of multiple address books.
More Information:
Remote Control Viewer
