Previous Topic: Address Book PropertiesNext Topic: Browse Repositories Dialog
Modify Global Address Book Properties
Use the Global Address Book Properties dialog to view the name of the CA ITCM, Windows domain or directory, and the current user. You can change these settings by entering the fields or by clicking Browse.
This dialog contains the following fields:
Management Server
Defines the name of the remote control manager for this personalized global address book (GAB).
Specify Username and Password
Requires you to supply a valid user name and password that have been granted access to a GAB defined by the manager. If False, the currently logged on user's credentials are used.
Default: False
<directory-specific title>
Defines the name of the domain or provider for this personalized global address book.
Note: The name of this field is directory-specific, for example, Domain Name for WinNT and LDAP Provider for LDAP.
User
Defines the name of the selected user of this personalized global address book.
Password
Defines the password of the selected user.
This dialog contains the following button:
Browse
Selects either the Windows domain or directory you want to use when selecting a new user for the address book.
The Browse Repositories dialog or the (Browse) Users dialog appears, as appropriate, displaying either a list of available domains and directories or users, respectively.
