Previous Topic: QueryStartRequestsNext Topic: AbortStartRequest
DequeueStartRequest
The DequeueStartRequest operation removes a start request form instance from the queue.
  1. Create a process.
  2. Drag the Execute operator to the Designer.
  3. Double-click the Execute operator to open the Properties palette.
  4. Enter the required parameters.
    Catalyst Security
    Username: (Catalyst user name)
    Password: (Catalyst password)
    Claims:
    ClaimName: Username
    ClaimValue: pamadmin
    PasswordClaims:
    ClaimName: Password
    Execute
    CatalystBrokerURL: https://hostname:7443/ucf/BrokerService
    MdrProduct: "CA:00074 (CA Process Automation)"
    MdrProdInstance: "CA:00074:01"
    Operation Category: "CA Process Automation"
    Operation: DequeueStartRequest
  5. Dequeue the start request form instance that is in the Queued state.
    1. In the Execute Properties, click Parameters.
    2. In the DequeuetStartRequestRequest tab, enter the Instance value "SRF_Queue_x" (where x is the instance ID of the request form to dequeue). For example, "SRF_Queue_5829."
  6. Run the process.
  7. Review the output.
    In the following illustration, the output parameters display the dequeued start request form. The State returns as Failed because the start request form instance was dequeued.
    Note: You can only dequeue the queued start request form instance.
    Dataset results for DequeueStartRequest
