Previous Topic: Start Request OperationsNext Topic: SubmitStartRequestForm
Examples
The following topics explain how to use start request operations with the Catalyst Execute operator.
QueryStartRequestForms
To query start request forms, use the QueryStaonrtRequestForms operation.
  1. Create a process.
  2. Drag the Execute operator to the Designer.
  3. Double-click the Execute operator to open the Properties palette.
  4. Enter the required Catalyst Security and the required Execute parameters.
    Catalyst Security
    Username: (Catalyst user name)
    Password: (Catalyst password)
    Claims:
    ClaimName: Username
    ClaimValue: pamadmin
    PasswordClaims:
    ClaimName: Password
    Execute
    CatalystBrokerURL: https://hostname:7443/ucf/BrokerService
    MdrProduct: "CA:00074 (CA Process Automation)"
    MdrProdInstance: "CA:00074:01"
    Operation Category: "CA Process Automation"
    Operation: QueryStartRequestForms
  5. Create a recursive filter that queries start request forms in the Library.The filter can restrict the search by path, recursively, and by keywords (tags).
    1. In the Execute Properties, click Parameters.
    2. On the Filter tab, enter the following parameters:
      LookUpPath: Defines the path to query for start request forms. In this example, we are querying for start request forms in the "Bulk_SRFs" parent folder.
      IsRecursive: true
      Keywords: Defines one or more keywords (such as run, queued, and complete) with which to query start request forms.
      You can also conduct a query without keywords, as in the following illustration:
    Parameters of QueryStartRequestForms for REST
    1. Click Save and Close.
  6. Run the process.
  7. Review the output.
    For example, in the following illustration there are 25 start request forms (with variables) from the provided LookUpPath:
    Dataset response for QueryStartRequestForms
