Previous Topic: Querying CapabilitiesNext Topic: Process Operations
Custom Operations
Catalyst Process Automation Services support custom operations. Custom operations are available for:
Note: Custom operations require secure access. If the "use.catalyst.claims.credentials" value is true, then claims are also required for CA Process Automation credentials.
In the Execute operator (inside the Catalyst module), select a custom operation from the Operation drop-down list.
The Export option is selected in the Operation drop-down menu.
