The Catalyst container and Catalyst Process Automation Services are embedded in CA Process Automation. Communication is optimized among the Catalyst container, Catalyst Process Automation Services, and CA Process Automation.
Catalyst Process Automation Services include an embedded connector that exposes the UCF interfaces. Any UCF client application (including the CA Process Automation Catalyst operators) can use the UCF interfaces.
Any Catalyst client can use the CA Process Automation connector to perform the following actions:
Important! Do not install other connectors in the Catalyst Process Automation container.
Copyright © 2014 CA.
