This chapter describes concepts and procedures relevant to configuring common default settings for operators at the category level. This chapter also addresses configuring values for variables that can be defined for custom operator groups.
Note: You do not need to configure modules (operator categories). The recommended best practice is for the content designer to create global datasets for the module settings. The content designer then uses expressions that reference the dataset variables in the operator properties.
This section contains the following topics:
Operator Categories and Operator Folders
Example: Category Settings Used by Operator
Configuring Operator Categories
Configure Values for a Custom Operator Group
Delete a Custom Operator Group Configuration
Category Configuration and Operator Inheritance
Enable or Disable an Operator Category
Enable or Disable a Custom Operator Group
Override Settings Inherited by a Category of Operators
Override Inherited Values for a Custom Operator Group
Operator Categories and Where Operators Run
