Administer Operator Categories and Custom Operator Groups › Override Settings Inherited by a Category of Operators
An administrator with Domain Administrator rights configures categories for operators at the Domain level. An administrator with Environment Configuration Administrator rights can override inherited settings at any of the following levels:
- Environment
- Orchestrator
- Agent
Operator category settings that have been configured at the Domain level are displayed as Inherit from Domain. This setting is in a drop-down list, where other valid choices are Enabled and Disabled. Select Enabled to edit the inherited settings. Select Disabled to disable operators in the selected category.
You can override inherited settings for any category of operators at one or more levels.
- Click the Configuration tab.
- (Optional) Override selected settings at the environment level as follows:
- Right-click the selected environment and select Lock.
- Click the Modules tab.
- Select a category, click the drop-down list for Enable/Disable and select Enabled.
- Right-click the category and select Edit.
The properties of the selected category are displayed in a scrollable list.
- Change one or more inherited settings.
- Click Save.
- Right-click the environment and select Unlock.
- (Optional) Override selected settings at the Orchestrator level as follows:
- Expand Orchestrators, select an Orchestrator, and click Lock.
- Click Save.
- Click Unlock.
- (Optional) Override selected settings at the agent level as follows:
- Expand the Agents node, select an agent, and click Lock.
- Click Save.
- Click Unlock.
