Administer Operator Categories and Custom Operator Groups › Enable or Disable an Operator Category
Operator category settings are typically configured at the Domain level. By default, operator category settings for environments are Inherit from Domain. By default, operator category settings for Orchestrators and agents are set to Inherit from Environment.
Access the Modules tab for an environment, Orchestrator, or agent to:
- Enable one or more operator categories.
- Disable one or more operator categories.
- Configure one or more enabled categories.
- Click the Configuration tab.
The Configuration Browser opens.
- Take one of the following actions to place a lock at the desired level:
- Expand the Domain node, select the target environment and click Lock.
- Expand the Orchestrators node, select the target Orchestrator and click Lock.
- Expand the Agents node, select the target agent and click Lock.
- Click the Modules tab.
- Select an operator category, click the Enable/Disable column, and select either Enabled or Disabled.
- Click Save.
- Click Unlock.
