Administrators who can lock the Domain can configure or change default settings for operator categories at the Domain level. These configurations are inherited. You can edit these settings at the environment, Orchestrator, and agent levels. For details, see Override Settings Inherited by a Category of Operators.
Default values for all operator category fields can be overridden at the operator level. The values you enter for any operator category are all default values. When an operator is configured with a blank field, that operator inherits the default value of the corresponding field from the category setting. When you make a selection of a value in the Module tab, nothing gets enabled or disabled. You can specify all of the defaults, at your discretion. (When you configure these same options at the operator level, selection of one option disables the others.)
Note: For more details, see the Content Designer Reference for the operator configuration of these same fields.
To expand a field for an entry that is longer than the space provided, right-click the field and select Expand. A dialog with a text box opens.
