Previous Topic: Override Settings Inherited by a Category of OperatorsNext Topic: Operator Categories and Where Operators Run
Override Inherited Values for a Custom Operator Group
An administrator with Domain Administrator rights configures custom operator groups at the Domain level. An administrator with Environment Configuration Administrator rights can override inherited settings at the environment level.
Note: Unlike operator categories, you cannot override values for custom operator groups at the Orchestrator or agent level.
Custom operator group settings that have been configured at the Domain level are displayed as Inherit from Domain. This setting is in a drop-down list, where other valid choices are Enabled and Disabled. Select Enabled to edit the inherited settings. Select Disabled to disable custom operators in the selected group.
You can override settings that the selected environment inherits from the Domain.
  1. Click the Configuration tab.
  2. Right-click the selected environment, then select Lock.
  3. Click the Modules tab.
  4. Select a category, click the drop-down list for Enable/Disable, and select Enabled.
  5. Right-click the category, then select Edit.
    The properties of the selected category are displayed in a scrollable list.
  6. Change one or more inherited settings.
  7. Click Save.
  8. Right-click the environment, then select Unlock.
