Administer Operator Categories and Custom Operator Groups › Enable or Disable a Custom Operator Group
Custom operator group settings are typically configured at the Domain level. By default, custom operator group settings for environments are Inherit from Domain.
Access the Modules tab for an environment to:
- Enable one or more custom operator groups.
- Disable one or more custom operator groups.
- Override settings on one or more enabled groups.
- Click the Configuration tab.
The Configuration Browser opens.
- Expand the Domain node, select the target environment and click Lock.
- Click the Modules tab.
- Select a custom operator group, click the Enable/Disable column, and select either Enabled or Disabled.
- Click Save.
- Click Unlock.
