If required you can update an existing repository in CA OM Web Services.
A numbered list of repositories is displayed.
Note: This option returns you to the main Repository Settings Menu.
The domain format of a repository is:
ENFSYSID:DRASSERV:REPSNAME;
where
Specifies the CA Event Notification Facility System ID.
Specifies the DRAS server ID.
Specifies the repository name as defined in DRAS by the ACCESS REPOSITORY statement.
Note: The repository description is a reminder of the intended function of this repository reference.
Specify release numbers in the format N.N (for example, CA View® r12.0 would be 12.0).
After entering this information, you can see a success or failure message, such as COMMND999I: Repository Command completed successfully.
After making changes to the Repository Definitions the Create Report List Data Dictionary menu appears.
