Post-Installation and Configuration Tasks › Configure CA OM Web Services › Create or Manage Repository Definitions › Open Repository Settings
Using the CA OM Web Services Configuration Tool, you can list the current repositories that are defined to CA OM Web Services, remove, add, and update repositories.
- Launch either Configure_Web_Services or Change_Repository_Settings.
- Follow steps that are listed at Configuration Tool First Steps.
- (Optional) Complete CCI and the License Server sections, if running Configure_Web_Services.
When the Repository Settings Section opens you can see a list of several options, including a Continue to Next Section option. You can repeat the other options as required, and can then exit from this section by selecting Continue to Next Section.
- (Optional) Run one or more of the following:
- Insert Repository
- List Current Repositories
- Remove a Repository
- Update a Repository.
- Select Continue to Next Section.
The Create Report List Data Dictionary Entries section opens.
