Previous Topic: List Current RepositoriesNext Topic: Update a Repository
Remove a Repository
You can remove repositories from the CA OM Web Services repository definition file.
Note: The actual repositories are unaffected.
  1. Following the instructions listed in the section Open Repository Settings navigate to the Repository Settings menu.
  2. Select Remove a Repository.
    A numbered list of repositories is displayed. Each repository is listed in the following format: Name - Description.
  3. Do one of the following:
    After entering this information a success or failure message is displayed. For example, COMMND999I: Repository Command completed successfully.
  4. (Optional) Repeat steps 2 and 3 for each repository you want to delete.
  5. Select Continue to Next Section.
    After making changes to the Repository Definitions the Create Report List Data Dictionary appears.
