Previous Topic: Update a RepositoryNext Topic: Create Report List Data Dictionary Entries Procedure
The Report List Data Dictionary is an XML formatted file that includes an entry for each repository that is defined in the Repository Definition File. Each entry in the Report List Data Dictionary file defines internal information about the fields that are supported for the CA OM Web Services requests. The matching name entries in the Report List Data Dictionary and the Repository Definition File are required to process requests to the CA OM Web Services for each repository.
Before creating the Report List Data Dictionary for the Web Service, ensure at least one valid repository entry is defined to CA OM Web Services.
Create or re-create a Report List Data Dictionary when:
When the Create Report List Data Dictionary section of the CA OM Web Services Configuration Tool is run, the repository definitions that exist in the Report List Data Dictionary (RLDD) are updated as they are encountered. Also the entries for new repositories are inserted.
