Previous Topic: Configure the License ServerNext Topic: Open Repository Settings
Create or Manage Repository Definitions
Repository definitions identify each repository that the CA OM Web Services accesses. You must specify an entry for each repository that the Web Service accesses in the repository definition file. The repository definition process can be accomplished using the configuration tool.
Important! If you want to migrate repositories from CA OM Web Services 1.0 installation, see Migration Information before continuing with this section.
