To add a repository definition to the repository definition file, you have to use the Configuration Tool. The following repository information must be entered to add it into CA OM Web Services:
Specifies the name to call the repository in CA OM Web Services. The name provided to the configuration tool is how the configuration tool refers to the repository in the future.
Refers to the Domain. The three-part entities that identify each Host OM Product repository accessible on the network.
The repository description is a reminder of the intended function of this repository reference.
View – CA View®
Bundl -- CA Bundl®
Dispatch – CA Dispatch™
The release number of your host OM system (CA View®, CA Bundl®, or CA Dispatch™).
Note: The list displays all the available repositories if you have already entered valid CCI information. If you need to enter CCI information, launch either Configure_Web_Services or Change_CCI_Settings.
Note: If you select this option you are navigated to the main Repository Settings menu.
Note:
The domain format of a repository is:
ENFSYSID:DRASSERV:REPSNAME;
where,
Specifies the CA Event Notification Facility System ID.
Specifies the DRAS server ID.
Specifies the repository name as defined in DRAS by the ACCESS REPOSITORY statement.
Note:
Notes:
After entering this information, a success or failure message displays. For example COMMND999I: Repository Command completed successfully.
Note:
After making changes to the Repository Definitions the Create Report List Data Dictionary appears.
