Before you begin the installation, verify that the following conditions are met. Failure to to comply with these requirements can result in data loss, increased down time, software conflicts, or a failed installation.
Verify that each of the Windows servers has the following software installations and configurations in place:
Standalone Server |
Distributed NFA Console Server |
Distributed Harvester Server |
Distributed 3-Tier DSA Server |
* The installation program either does not open or does not complete successfully unless this requirement is met.
** If the server fails to pass the check for this requirement, a warning message opens.
Note: To support non-Latin characters such as Japanese and Simplified Chinese, any command line clients that you use for installation must be configured for UTF-8 encoding. If UTF-8 encoding is not enabled, these characters may not display properly during installation.
