A browser is required on the NFA console or standalone server. Microsoft Internet Explorer version 8 is recommended. Other browsers or browser versions may work with CA Network Flow Analysis, but have not been tested.
Note: To set up CA Network Flow Analysis and work with data in the CA Performance Center Console, use Internet Explorer 8 with compatibility mode turned off. To work in CA Network Flow Analysis directly, you can use Internet Explorer 7 or 8 with compatibility mode turned on or off.
If Internet Explorer 8 Developer Tools are installed, you can turn off compatibility mode for the current browser session:
