We recommend that you create an empty TrapConfiguration key in the Windows Registry to prevent the SNMP service from logging false positive events.
reg add HKLM\SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration
If the command executes successfully, the return value is: "The operation completed successfully."
The TrapConfiguration registry key is created in the following location: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SNMP\Parameters.
