Preparing Windows Servers for the Upgrade › Configure the IP Address Format on Windows Servers
Make sure that the connections for your Windows installation servers are not set up to bind to IPv6 addresses.
Note: These instructions are based on the assumption that each server has a single network interface card, which is the recommended configuration.
- Log in to the server as an administrator.
- Open the Network Connections window:
- Open the Control Panel and click Network and Internet.
The Network and Internet window opens.
- Click Network and Sharing Center.
The Network and Sharing Center window opens.
- Click Change adapter settings on the left side of the window.
The Network Connections window opens.
- Right-click the connection and select Properties from the menu.
The Properties dialog box opens.
- Clear the check box labeled 'Internet Protocol Version 6 (TCP/IPv6),' if it is selected.
- Click OK.
Any changes that you have made are saved. The Properties dialog box closes.
- Close the Network Connections window.
