System Requirements › Windows Operating System Requirements
Microsoft Windows servers that host CA Network Flow Analysis components have the following additional operating system requirements.
Microsoft Windows 2008 R2, Standard edition on a 64-bit processor, with:
- Latest service pack and all important updates installed
- CA Performance Center 2.2.00 installed
- .NET Framework 3.5 SP1
If the .NET Framework software is missing or version 4.0 is installed, the a prerequisite check causes the installation or upgrade program to exit.
- Java Runtime Engine (JRE) 1.6u41 which is included with the ISO files from CA Technical Support.
If the installation server does not have JRE version 1.6 installed, the installation or upgrade program fails to launch. We recommend that you install JRE 1.6u41, the version that was used in CA Network Flow Analysis 9.1.2 testing. Untested JRE versions may produce unexpected results.
- English, Chinese (Simplified), French (France), or Japanese language
- Service Control command (sc.exe file) in the Windows System32 directory
This command is required for command-line operation. If the file is missing, a prerequisite check causes the installation or upgrade program to exit.
- Minimum display resolution of 1024x768 (XGA)
- NFA console and standalone servers: ASP.NET 2.0 installed, including COM+ network access, IIS, and ASP. ASP.NET 2.0 comes with the .NET Framework 3.5 SP1
- Operating system configured as described in this document, including SNMP enabled
- (Recommended) Remote Desktop Connection enabled to allow remote access by the administrator
Notes:
- CA Network Flow Analysis 9.1.2 supports installation on servers with IPv4 addresses. Installation is not supported at this time on servers with IPv6 addresses.
- We recommend that you configure a single NIC (network interface card) on each server.
- The requirements that are described throughout this section apply to both physical and virtual deployments.
