![Previous Topic: Configure DEP](574.png)
![Next Topic: Disable Unneeded Services](573.png)
Preparing Windows Servers for the Upgrade › Configure the Recycle Bin
Optionally, configure the way the Recycle Bin deletes files.
- Right-click the Recycle Bin and select Properties.
The Recycle Bin Properties dialog opens.
- Select Local Disk (C:).
- Select "Don't move files to the Recycle Bin. Remove files immediately when deleted."
- Click Apply.
- Repeat steps 2 through 4 for each additional drive that you want to configure.
- Click OK.
![Previous Topic: Configure DEP](574.png) ![Next Topic: Disable Unneeded Services](573.png)
