A two-tier distributed deployment of CA Network Flow Analysis may include one or more Linux Harvester servers. To upgrade the Harvester software on a dedicated Linux server or virtual machine, complete the steps in this topic.
Before You Begin: Verify that the server is upgrade-ready as described in Verify Preparation of the Linux Servers.
Follow these steps to prepare the NFA console server for the Harvester upgrade:
The Console tool prepares the system for the upgrade.
java -jar consoletool-exe.jar
The ConsoleInfoToPollerTool<yyyy-mm--dd>.log file opens when the Console tool completes--whether the tool completes successfully or fails. The log is saved in the <install_path>\Reporter\Logs\ directory.
The Console tool cannot complete successfully if the system has undeployed interface aggregations or unscheduled merge or delete interface tasks. If the tool does not complete successfully, note the error messages in the log file and contact CA Support.
The pump service stops.
Follow these steps to upgrade the Harvester:
You can install the software locally or remotely--for example, by using ssh when you are logged in with root privileges.
Note: If you do not have root access, use an account with sudo privileges.
ulimit -n ulimit_number
Example:
ulimit -n 65536
You can install or upgrade the software locally or remotely--for example, by using ssh when you are logged in with root privileges. If you do not have root access, use an account with sudo privileges.
chmod u+x NFHarvesterSetup9.1.3.bin
ls -al
The file permission settings are displayed.
./NFHarvesterSetup9.1.3.bin
A check verifies that the server has a supported version of the Java Runtime Engine (JRE) installed. If the check fails, an error message opens. You cannot launch the installation or upgrade program until this problem is corrected.
If the server passes the Java prerequisite check, the program starts and the language selection screen opens.
A check determines whether the installed version of CA Network Flow Analysis is supported for upgrade. If a supported version is located, the Prior Installation Detected message opens.
The Welcome screen opens.
A check verifies that the Console tool completed successfully on the NFA console server. If the tool did not run successfully, an error message opens and the upgrade stops.
If the server passes the check, the License Agreement screen opens.
Prerequisite tests are run to identify problems on the server. If a problem is found, an error message opens. A critical problem causes the upgrade program to exit. If the problem is not critical, the Pre-requisite Check Warning message or other warning message opens, which gives you the option to make corrections now or after the upgrade is complete.
Once the server passes the required checks successfully and you dismiss any warnings that appear, the Choose Install Folder screen opens. This screen displays the original root installation path as the default setting.
Important: If you do not use the original installation path, the upgraded software will not run properly.
If the program does not find certain expected directories in the installation path, an error message opens and the upgrade stops. This problem does not occur when the previous software installation is fully functional.
The Pre-Installation Summary screen opens.
The Installing Harvester screen opens, which shows the upgrade progress. When the upgrade is complete, the Install Complete screen opens and reports any errors that occurred.
The upgrade program closes. The Harvester is upgraded and the CA Network Flow Analysis services are started.
Next:
