Troubleshooting › Java Is Not Installed
If you attempt to launch the installation or upgrade program on a server that does not have a supported version of the Java Runtime Engine (JRE), an error message opens. You must install a supported version of the JRE, before you can proceed.
The error message reads:
"No Java virtual machine could be found from your PATH environment variable. You must install a VM prior to running this program."
- (Optional) Determine which JRE version the server is running:
- Enter the following command at a command prompt or in a terminal window:
java -version
The command returns the JRE version that is installed.
- Download the appropriate JRE installation file to the installation server.
- (Windows) Run the JRE .exe installation file:
- Open the Run window: Select Start, Run.
- Specify the path and file name for the installation program in either of the following ways:
- Click Browse and use the Browse window to locate and select the file.
- Enter the path and the file name in the Open field.
- Click OK.
- Follow the prompts to complete installation.
- (Linux) Run the JRE .bin installation file:
- Navigate to the JRE .bin file location in a terminal window.
- Enter the following command:
./jre
The JRE installation program starts.
- (Optional) Repeat step 1 to verify that the JRE version is updated correctly.
