Previous Topic: Select a Smart Card Reader to Connect DialogNext Topic: RC Web Viewer Interface
gui_rcLaunch Command—Launch Viewer
The guiLaunch.exe program provides a command line interface for launching remote control functionality.
gui_rcLaunch.exe [{VIEW | REPLAY} [Options]]
If no command arguments are specified, the program just launches Remote Control. Use quoted "" strings for values containing spaces. Use \" to insert a quote.
VIEW
Specifies the Remote Control viewer component.
REPLAY
Specifies the Remote Control replayer component.
/M {STEALTH|VIEW|SHARED|CLASSROOM|EXCLUSIVE|SECURE|MEETING}
Indicates the type of connection.
Default: SHARED
/N computername
Specifies the remote computer display name.
/A address
Specifies the address of the remote computer.
/T {TCP}
Indicates the connection protocol.
Note: Only TCP is supported currently.
/U username
Defines the user name.
/P password
Defines the user password.
/S {NORMAL|AUTOPAN|SCALE|SHRINK}
Indicates the type of scroll mode.
Default: NORMAL
/C {<32|16|12|8|6>BITCOLOR|<8|4|1>BITGREY}
Indicates the color depth for bitmaps.
Default: 32BITCOLOR
/R filename
Specifies the file name and path for recording the session, or the file name and path of a recorded session to be replayed.
Note: If /R is specified, the viewer records the current session to the specified file name.
/L
Specifies authentication using the credentials of the current user. This permits you to connect to a remote host without specifying a user name or password. The system assumes that the logon credentials are also to be used on the remote machine.
/I
Specifies interactive mode.
Note: If /I is specified, the viewer operates in an interactive mode and displays the Connection Settings dialog, letting you set various options before connecting.
/F
Specifies full screen mode.
/D
Specifies that reduced bitmaps be dithered.
/E
Specifies that fonts not be embedded.
Note: The viewer always displays the Connection Settings dialog if the user name, password, or address is not specified on the gui_rcLaunch command line.
Examples
The following example connects to host1 and displays the Remote Control viewer:
gui_rcLaunch VIEW /A host1 /U myuser /P secret
This example displays the Connection Settings dialog, but the viewer does not connect until the Connect button is clicked:
gui_rcLaunch VIEW /A host1 /U myuser /P secret /I
Even though /I is not specified, this example displays the Connection Settings dialog since the password was not given:
Additional examples:
"C:\Program Files\CA\DSM\bin\gui_rcLaunch.exe" VIEW /A 123.45.678.999/U Administrator/P Test
"C:\Program Files\CA\DSM\bin\gui_rcLaunch.exe" VIEW /M SHARED/A 123.45.678.999/U Administrator/P Test/I
More information:
Scroll Mode
Connection Settings Dialog
Remote Control Viewing Modes
