Previous Topic: Show as Separate WindowNext Topic: Clipboard
Scroll Mode
Provides scrolling options for the viewer, as described in the following table:
Menu Option
Toolbar Button
Function
Normal
Scroll Mode - Normal button
Displays the host image within the viewer window without modification.
Auto Pan
Scroll Mode - Auto Pan button
Shifts the display of the active area as the mouse moves around the screen. Applies to a viewer computer with a smaller resolution than the host computer.
Scale to Fit
Scroll Mode - Scale button
Scales the host image to fit the viewer window.
Shrink to Fit
Scroll Mode - Shrink button
Shrinks the host image to fit the viewer window.
Keep Aspect Ratio
N/A
Applies to Scale to Fit and Shrink to Fit modes. Keep Aspect Ratio proportionally scales the host image within the viewer window.
More information:
gui_rcLaunch Command—Launch Viewer
View Tab
