Use the Select a Smart Card Reader to Connect dialog to select a virtual card device for smart card authentication. This dialog appears only if more than one smart card reader is attached to the system.
This dialog contains the following fields:
Defines the name of the smart card reader to be used to connect to the host.
Indicates whether a smart card is inserted in the card reader.
