Previous Topic: gui_rcLaunch Command—Launch ViewerNext Topic: Session Tab
RC Web Viewer Interface
The RC Web Viewer interface displays the Connection Settings dialog, which lets you configure the connection to a remote computer. From this dialog you can view, modify, and select a connection type, address, and user name. Additionally, an Options portlet lets you set session, viewing, and keyboard options. Use the Options/Hide Options button to display or hide the portlet.
The Options portlet contains the following tabs:
More information:
Connection Settings Dialog
