Previous Topic: Configure Viewer Display and Control OptionsNext Topic: Browse for Folder
Configure Recording Options
Use the Record tab to enable or disable the default connection settings for the recording of remote control sessions and to choose where to save the recording.
Note: These settings can be overridden at connection time, using the Viewer tab of the Connection Settings dialog.
To configure remote control recording options
  1. Right-click the Viewer node and select Properties.
    The Viewer Properties dialog opens.
  2. Select the Record tab.
  3. (Optional) Specify whether recording begins at the start of each session. By default this option is not enabled.
    Note: This behavior may be changed before establishing a session by adjusting the setting on the Viewer tab of the Connection Settings dialog.
  4. Specify the default path where you want to save recorded sessions. If this is left blank, the system-wide Temporary folder is used.
    Note: This path may be overridden before establishing a session by adjusting the setting on the Viewer tab of the Connection Settings dialog.
  5. (Optional) Click Browse to access the Browse for Folder dialog, which lets you navigate the folder path for saving recorded sessions.
  6. Click OK.
    Your recording options are saved.
More information:
Connection Settings Dialog
