The Viewer Properties dialog lets you set up and view properties of the viewer.
Note: Some dialogs on non-English operating systems are unable to display and accept non-English characters, which affects the DSM Explorer, DSM Reporter, and Remote Control viewer. This is because the default font used is MS Sans Serif, which does not support all character sets. The solution is to select a different font for the dialogs, such as the MS UI Gothic, by clicking the View, Fonts, Dialogs menu command in the DSM Explorer.
This dialog contains the following tabs:
