See the chapter Understanding ENS for information about actions.
To add an action
Note: On OpenVMS, you must include the appropriate file extension on the corresponding action routine, for example YOUR_ACTION.COM for a command file.
Click the required checkbox in Action Type to determine how the action will be executed, and the way in which ENS will communicate events to it. For example, one dispatch for each event and each userdata item.
Copyright © 2010 CA.
