This chapter explains how to set up the components of ENS using the configuration editor to let Console Manager notify you of events detected on the consoles of serviced systems.
See the chapter Understanding ENS for a detailed description of events, scans, filters and actions. If you need only a quick reminder of the main points in creating filters and dispatches, then review the hints given in the chapter Understanding ENS.
If you need expert assistance in setting up ENS for your particular environment, contact your local CA representative.
This section contains the following topics:
Steps in Creating Filters, Dispatches and Actions
Using the Command Line Interface to the Configuration Editor
Using the DECwindows Interface to the Configuration Editor
Example of How to Set Up a System to Scan for an Event
Copyright © 2010 CA.
