Previous Topic: ActionsNext Topic: Invoking Actions
Action Attributes
Each action has attributes as described in the following table.
Attribute
Description
Name
A unique name for the action. It is selected when creating dispatch entries in filter records.
Information
Description of what the action does.
Command
The name of the command procedure or image residing in the default actions directory. The directory specification must not be specified when entering this item.
Action Type
One of:
One instance of the action for each event and each userdata item.
One instance of the action for all events and all userdata items.
One instance of the action for all events and each userdata item.
Parameters to Pass to Action
In the case of actions treated as scripts and command procedures (that is, parameters are passed on the command line) each item of the event which is required by the action must be selected.
