Actions can be invoked each time an event occurs, or they can be dispatched once and then be passed many events. The type of action being used determines the data passing method ENS uses to inform the action of the event or events destined for it.
There are two data passing methods: using the command line or an interprocess communication (IPC). The following table explains them in detail.
Data Passing Method |
Description |
Action Type |
Command line |
All event details are passed on the command line used to dispatch the action. This method is used for actions requiring only details of the single event they were dispatched for. |
Shell script, command procedure or image |
IPC |
All event details are passed to the action through a UNIX domain socket or OpenVMS mailbox. This method is used for actions that are to be sent multiple events. |
Image |
The values you give to the Action Type attribute determines the data passing method. The possible values are shown in the following table.
Action Type |
Dispatch Behavior |
Command procedure |
Command line |
One instance of the action is dispatched for each event and each userdata item. |
Image |
IPC |
One instance of the action is dispatched for all events and all userdata items. |
Image |
IPC |
One instance of the action is dispatched for all events and each userdata item. |
Copyright © 2010 CA.
