Previous Topic: QueryDatasetNamesNext Topic: UpdateDatasetParameters
QueryDatasetParameters
Use the QueryDatasetParameters operation to search the specified path for dataset parameters.
Follow these steps::
  1. Create a new process.
  2. Drag the Execute operator to the Designer.
  3. Double-click the Execute operator to open the Properties palette.
  4. Enter the required parameters.
    Catalyst Security
    Username: (Catalyst user name)
    Password: (Catalyst password)
    Claims:
    ClaimName: Username
    ClaimValue: pamadmin
    PasswordClaims
    ClaimName: Password
    Execute
    CatalystBrokerURL: https://hostname:7443/ucf/BrokerService
    MdrProduct: "CA:00074 (CA Process Automation)"
    MdrProdInstance: "CA:00074:01"
    Operation Category: "CA Process Automation"
    Operation: QueryDatasetParameters
    PathName for the QueryDatasetParameters operation
  5. Run the process.
  6. Review the output.
    This illustration shows the dataset name with the Value, Type:
    Dataset with parameter name returned.
