Installation of the CA Process Automation Domain Orchestrator depends on certain components being present. Therefore, installation of CA Process Automation is done in two major phases:
Both steps must be performed whenever installing, reinstalling, or upgrading CA Process Automation.
Installation can be performed from physical media, from a copy that you make of the physical media or that you obtain though download.
You can exit the installation process at any time. If you cancel, a confirmation pop-up displays. If you confirm the cancelation, the installation steps you have taken are rolled back.
If you have a load balancer, we recommend that you set up the Domain Orchestrator as a clustered Orchestrator, even if you have no plans to cluster at the present time. If you decide to cluster later and have not set up the Domain Orchestrator as clustered, you must reinstall the Domain Orchestrator to support clustering. For details, see:
Subsequent installations require certain values that you configure during Domain Orchestrator installation. For example, certain passwords must be reentered during upgrade or installation of other Orchestrators. A simple way to retain a record of values you enter is to create a plan for passwords before you begin interactive installation. For example, record passwords for the following plus any database specific passwords.
