Each clustered Orchestrator needs load balancing. If you have an F5 load balancer, you can use it to balance the processing of operator requests or web services requests across clustered nodes of the target Orchestrator.
Before you install the first node of a clustered Domain Orchestrator or another clustered Orchestrator, prepare F5 to perform load balancing.
First, gather the following information:
Then, configure the following F5 elements so that the elements function with CA Process Automation.
For CA Process Automation, a node is any host or virtual server on which an Orchestrator cluster node is installed (or could be installed in the future).
For CA Process Automation, each pool includes the Orchestrator cluster nodes that belong to the same clustered Orchestrator.
For CA Process Automation, an iRule routes operator requests that target the touchpoint of a clustered Orchestrator.
F5 can have several virtual servers. CA Process Automation is set up as one of the virtual servers.
