Ports are configured during installation. When configuring network ports, accept defaults except when:
Review the use of ports in Ports Used by CA Process Automation and plan for substitutions for any ports that are in use in your network or on the applicable host. With the exception of the port for agents and for CA EEM, all other properties are stored in the OasisConfig.properties file in install_dir/server/c2o/.config. If a conflict occurs after installation, you can modify this file manually.
